In nokia E63 how can i install a dictionary?
Hey Billy!
DICTIONARY is the most useful software in any mobile. I had it in my Nokia N72, but my model was Symbian V 2.0. As you mentioned above that you want dictionary for Nokia E63, so we have to find which Symbian version is Nokia E63. Nokia E63 is a Symbian supported mobile which is 3rd generation of Symbian and the Symbian version of this mobile 3. There are many sites from where you can download dictionary.
I recommend you to visit these two sites and find the dictionary.sisx file.
1. Mobile9.com
2. Dotsis.com
Once you download the dictionary, transfer it to your mobile via cable or by Bluetooth. When you finished transfer it, open the menu of the mobile and ho to the folder from file manager where you have transferred the .sisx file.
Found that file and launch it. You are done
Thanks
Hi Billy Gil!
Installation Procedure:
Hope this can help.
