Tony Bailey
50 points
Posted on - 07/08/2012
Nokia's Remote Device Access service was able to detect a Nokia Lumia 1001 which is suspected to be Nokia's first Windows Phone device. If this is true, how much and when would Nokia be selling their new device?
Nokia Lumia 1001 a Windows Phone 8 device
Yes, this is true for Nokia Lumia 900 an Nokia Lumia 1001. And the nokia Lumia 1001 is suspected or rumored to be the next Windows Phone 8. But some say that the Lab Engineers at nokia are just playing around or probably testing it, that is why it is appearing in the Remote Device Access. You should check out the Nokia World event on September 5, and see what happens.
The rumor mill always has something to say and you can always count on them to give you the most outrageous of speculation and ‘leaks’. Also I should not try and take all the credit from them since some of these ‘leaks’ usually prove to be true. There has not been a Nokia Lumia 1001 but there has been the 800,900,820, 920 and recently the 925 launched in May.
