Nokia Lumia 710 Not Playing Videos on Browser
I really love my Nokia Lumia 710. It runs IE 9 which makes browsing the net good for me. But I do have a problem because it doesn’t play videos from Youtube and other sites. It just says “not supported.” How can I fix this and where to download?
Best Answer by Barrett Lawerence
Answered By 5 points N/A #142999
Dear,
In order to play video on any browser a flash player software is required. Flash players for mobile phones are available. Install flash player in your mobile to play videos on browser. Make sure the software source is reliable. You can also try different browser on your mobile. Without flash player any type of browser cannot work. Keep your mobile applications updated in order to get better service.
Thank You.
Answered By 0 points N/A #143000
Not only Nokia Lumia 170 version, this is a challenging task to many phones.
To solve this dilemma its better you try to download some of the latest Mobile Video Player Applications and confirm which one operates better with the version on your phone.
Next, if that does not solve the problem then you need to download Mobile Video Converter Applications because what causes the above problem is that the phone does not support the format of the video you are trying to play,
therefore, you need a Mobile Video convertor Application.
Listed below are some of the best latest Nokia Lumia Video converters;
Nokia Lumia 920 Video Converter, Nokia Lumia 620 Video Converter, Nokia Lumia 710
Video Converter¾
