Nokia Lumia 900 answer to Apple’s iPhone
What can Nokia Lumia 900 do now that it is being fixed for its bug? Will it really become iPhone's worst nightmare?
As the issued there is a bug caused on Nokia Lumia 900 phones. The problem was the network drop down. The network data connection drops due to a memory management issue.
Nokia authority says, the problem was solved and the customer can solve it by a software update for the Nokia Lumia 900 from the Nokia site.
As to your second question the battle for the smart phone market share is getting crazier. Where Apple wants to carryout its dominance with iPhone, on the other hand Nokia aims to make an impact with flagship Lumia series of phones.
So if you analyze the market of smart phones you will find out a battle goes on with the smart phones of four companies against each other. HTC One X, Nokia Lumia 900, Sony Xperia S and Apple iPhone 4S stack up against each other.
So you can say it as a nightmare of iPhone’s.
This issue Will Be difficult to answer, let try to make a one to one comparison and we will see at the end if we will get an answer.
At the screen, the iPhone has a Retina display high definition and 3.5 inches while the 900 has Lumia bare 4.3 inch screen with a resolution of 800 × 480.
Lumia The 900 has three touch buttons at the bottom of the screen while the iPhone has only one. both use a micro-sim, and both are equipped with microphone with noise reduction (note that when testing users finds that the most effective Lumia 900) and a 3.5mm jack.
In charging, the Lumia 900 is more generic since it has taken a micro-USB standard while the iPhone has a proprietary jack … if you forget the charger it will be easier to replace the micro-USB from GPS, the Kindle or the camera if you have a 900 Lumia.
The camera of the Nokia 900 is a Lumia 8Mpx Carl Zeiss camera with autofocus and dual LED flash. The iPhone is a classic 8Mpx with autofocus but the users says that the photos are more beautiful on the iPhone, even for videos despite the fact that the Lumia has a continuous autofocus in video making and that iPhone does not have one.
Multimedia at the Lumia is great for its big screen Clear Black makes the colors deeper. The speakers are of similar quality, responsiveness of the two mobiles is also similar and autonomy as well.
and finally the price which is a double for the IPhone.
we can say at the end that the iPhone should fear the lumina coming from behind.
Thank you.
