I am trying to find the settings for touch screen calibration on my Nokia Lumia 900 since I am having issues on texting and playing games on it. I could not find the options on where to do the calibration. Does Nokia Lumia 900 has this feature? If so, please help me on finding it. Thanks.
Nokia Lumia 900 Calibration Screen
Hi Barry,
Calibrating  your touch screen on Nokia Lumia is very easy. Slough the touch screen is calibrated at the factory but if you need to re-calibrate it just do the following:Â
Menu -> Settings -> Phone -> Touch Input -> Touch screen calibration
You will be prompted for simple instructions. Just follow them and Your issue is resolved. 🙂 Hopefully this was helpful for you.
Follow the steps that I provide  below promptly:
1.     Click menu then Settings
2.     Select Phone and under it select touch input
3.     You will see ‘Touch screen calibration’ option. Click on it and follow guidelines ahead.
More of these can be found at the Nokia FAQ section. Happy testing.
