Nokia Lumia 920 i get this Sync error 80004005
Get this error 80004005 while sync Windows Phone Desktop App
What type of information are you trying to sync? If it is music, there are some specific solutions listed below as well.
Here are a few solutions. Please try each one.
1. Restart the phone and the computer. Make sure the phone is disconnected from the computer prior to re-starting.
2. If trying to sync music, use the Windows Phone Desktop app to transition your music library for syncing.
The error occurred because you tries to login with another account in Outlook. This error is mainly a bug in the Lumia 920. Lumia doesn't allow changing the account details once you have entered one. Try one of the two options:
Windows phones don't have any fix to this error by now, but hopefully the coming up update will solve the issue.
Notifications
