Nokia Lumia 920 vs iPhone 5
Can i have the differences between these 2 devices
Cost
Features
Size
Best features in each
Cost
Features
Size
Nokia Lumia is based on Windows OS, while the iPhone 5 is based on Apple iOS 7 and it provides more internal storage (64 GB). Other than this basic difference there are many reasons to go for Lumia 920 as follows:
1. Nokia Lumia 920 has a better battery power with 16 days (standby) compared to 10.4 days (standby) in iPhone 5.
2. It has substantially higher resolution. Nokia Lumia provides 1280 x 768 pixels as compared to 1136 x 640 pixels in iPhone 5.
3. It has bigger screen size. Nokia Lumia has a bigger screen(4.5”) by 0.5 inches as compared to iPhone 5.
4. Nokia Lumia provides a faster CPU clock speed of 2 x 1.5 GHz, as compared to 2 x 1.3 GHz of former.
5. Nokia Lumia 920 provides a unique feature “Wireless charging”.
6. Iphone 5 provides a better flash with dual Led as compared to flash in Nokia Lumia 920.
7. Nokia Lumia 920 uses gyroscopic sensors to provide optical image stabilization
8. iPhone 5 provides Bluetooth connectivity through Bluetooth v4.0, while Nokia Lumia provides through Bluetooth v 3.0
9. IPhone 5S provides features such as Fingerprint sensor, slow-motion video capture, OpenGL ES version 3.0 support for higher-res gaming, free iWork apps.
Hi ILeo.Nerd,
The above mentioned are some of the major differences between Lumia 920 and iPhone5. Incase if you are interested to go deep in to the features of both devices, i will advice you to go through some decent articles. The articles below will give you a fair idea of what you want to know
iPhone 5 vs. Lumia 920: Which phone should you get?
Nokia Lumia 920 vs Apple iPhone 5
Nokia Lumia 920 vs. Apple iPhone 5: Specs, Features and More [VIDEO REVIEW
Regards
Antonette
