Nokia Lumia cell phone details
Hi i am sohel,
I know details of Nokia Lumia cell phone like description, Check specs,features and functions etc.
Specially Nokia Lumia 610,
Please help me any body.
Hi i am sohel,
Hello,Â
hope i can say something better of your known knowledge, Nokia lumia 610 Â is one of the latest smart phone by Nokia.
Nokia used a new OS called Microsoft Windows Phone 7.5 Mango. It has a 800 MHz CPU. Html 5 which gives you a new experience of Internet. Camera 5 MP, 2592х1944 pixels, autofocus, LED flash you can capture your best moments with it. Standard battery, Li-Ion 1300 mAh (BP-3L) you can now play music up-to 35 hours. You can have it with White, Cyan, Magenta, Black color.
Hoping that it will help you.
Thank you
Nokia is about to launch one of the most promising handsets in the budget range. Some say its better than the already launched Lumia 710,
I say, its definitely worth buying. If you are getting a taste at Windows Mango within a handset that competes with major league players, in speed as well as features, its no doubt, a must-buy phone. Its got all the features that anyone might be looking for,
but in a most promising price range. A 5 MP camera within a phone studded with a fast 800 MHz processor with social networking on the go, the new Nokia Lumia 610 is a strong contender in the short list of classy budget phones.
Thanks for your questions. Here is something I know about Nokia Lumia 610 .
It's relished on February 2012. 2G Network & 3G Network supported (GSM/ HSDPA) . Size 119*62*12mm, 77.6cc. Weight 131.5 g. TFT capacitive Touch screen, 16M colors. 480*800 pixels, 3.7 inches.
Multi touch capability with Corning Gorilla glass protection. 5 MP camera (2590*1944 pixel) With Geo-Tagging, Face Detection, Auto Focus, LED flash. Video capability 720@30fps.
No secondary camera. Alert type vibration with mp3 & WAV ringtone. Head phone jack 3.5mm. Internal 8 GB Storage. No card slot. GPRS class 10 (4+1/3+2 slots), 32-48 kbps. EDGE class 10 . Speed HSDPA 7.2 mbps; HSUPA 5.56 mbps. WLAN Wi-fi 802.11 b/g/n. Bluetooth v2.1. Micro USB v2.0.3. OS Microsoft windows phone 7.5 Mango.
CPU 800 MHz. Massaging SMS (threaded view), MMS, Email, Push Email, IM. Stereo FM Radio with RDS. Available with white, cyan, magenta, black Colors. A-GPS supported. Not Java supported. Micro SIM card support only.
Active Noise cancelation with dedicated mic. MP3/WAV/eAAC+/WMA Player. MP4/H.264/H.263/WMV Player. Document Viewer. Photo/Video Viewer. Voice memo/dial. Predictive text input. Standard Battery, Li-lon 1300 mAh (BP-3L). Stand-by Up to 580 hours(2G); Up to 530 hours(3G). Talk-Time Up to 6 hours 30 minutes(2G); Up to 7 hours 30 minutes(3G). Music play Up to 35 hours.
I think it's helpful for you.
Thanks and best regards
