I have a Nokia E 65 Mobile Phone which supports both Java and Simbian software.
It has wifi facility and I want to connect it with my laptop through wifi connection.
But it requires wifi software to install in my Phone set.
I also have wifi facility in my laptop.
So how can I get the software as well as to bridge it with my laptop?     Â
Nokia mobile E65 Wifi problem some body plz help me.
Hi Bashir,
Base on your testimony. You are having a problem with the form of compatibility. That is why your having a problem with your wifi to your laptop. So I suggest that review or recheck your wife application or what kind of wife you have in your both cellphone and laptop. At this action you will know if this is compatible or not. If not compatible will you can download application that compatible with your laptop or cellphone. Or you can try to use your infrared if available in your laptop because I sure that you cellphone has a infrared on it. if both of this you tried and nothing happened contact your administrative support for further info about your issue. That case both of us will know what the problem. Come back if you solve the problem in any of the action.
Thanks,Â
