NOKIA N73 default camera light
Is there any changes to make the NOKIA N73 default camera light opens continuously with the full brightness as it shows when using it in:
–>NIGHT mode –>RED EYE REDUCTION –>HALFWAY pressed brightness?
Are you trying to use your N73 camera light as a flashlight?
One step to make the light goes on continuously is by using it as a camcorder. That way, you can set the light on without having to press any key again. Also, you can try to download an application for your phone such as Fun Torch or the All In One Torch.
You can download the application from these sites:
Fun Torch – http://www.freeware-symbian.net/nokia-n73-device-84/flash-light-display-tag/phonetorch-download-9081.html
All In One Torch – http://series-sixty.blogspot.in/2007/09/update-all-in-one-torch.html
This application might be out of date but you can still download and install it. I hope this would help.
If you want to use the LED flash of your handset as a flashlight or torch, you can use one of these apps for Nokia N73:
