Hi. I just bought a new phone. It’s Nokia N8. Now, I would like to ask if it is possible to change the default language to Turkish. How can I do that? I’m a having trouble in Nokia N8 how to change language Turkish. Please help. Thank you.
Nokia N8 how to change language Turkish?
Hi Samantha,
Please follow the below steps in order to change your mobile phone language in your Nokia N8.
1. Please press the menu key. Which is in the bottom left hand side corner.
2. Then Go to the settings. After touching the settings tab find phone tab and click on it.
3. Now select language option and then select the phone language.
4. Select the language you want. It is Turkish, right.
5. Select Yes and save it.
Hello Samantha,
Probably you phone was shipped without a Turkish Language pack. This therefore means that you should download a language pack that includes Turkish Language from Nokia Care Point. Follow the link below to find a Nokia Care Point where you can download the language pack for your phone with Turkish Language Installed. https://www.nokia.com/en_us/phones or you can check http://betalabs.nokia.com/ Nokia beta labs for assistance because there are other people who had problems with other languages and got helped. Nokia support says that the language pack should be installed at Nokia support terminals so as not to damage the phone.
