Nokia n900 apps. Can anyone suggest best app’s for this phone.
Hi All,
Nokia n900 apps. Can anyone suggest best app's for this phone.
I have this phone for a while but could not get details or reviews on best applications for this phone.
Any suggestions is of great use.
Thanks
meows
Best Answer by eby_work
Answered By 0 points N/A #97145
1. Joikuspot has been a popular application among Nokia fans and they did not let down Nokia users when Nokia released Maemo5. Although it was not immediately available, Joikuspot is now ready for the N900. It is an early beta version but does its job very well. I have ATT so I only get EDGE, but those with an N900 on an HSPA network will sure want to have this app to connect to the internet everywhere.
2. Personal Photo Frame is a really simple but fun widget. It should come pre-installed on the N900 but well it didn’t. The Personal Photo Frame is just a widget that shows your pictures on the homescreen the cool thing is that it has a lot of options. You can select different sizes and determine how often pictures change. It really makes your homescreen look better with the pictures you have taken. You can also manually scroll through the pics right on the homescreen.
Answered By 5 points N/A #97146
NOKIA N-900 best apps you get from amazon,all accessories mobile shop,high apps.view,Joikuspot ETC.Joikuspot is serving for the N900 specially.
It is a beta version but does its job very well. if you don't from those sites then you can connect with NOKIA sites which can serve all for accessories and latest version if you are viewing on care Centre.
EDGE  with a N900 on an HSPA network will sure want to have this application to connect the internet review. And don't worry! for the latest version it will be use only default system for saving.
After available you can join new apps from your what not. Remember proper using must be good for all system,be happy!
Thanks
