Is Nokia the only maker of Windows Smart Phones
I was wondering if anyone else knows of a manufacturer of the windows smart phone other than Nokia.
Thank You.
Thank You.
In the previous years Microsoft produced Smart Phone from 2003. But now Nokia join with Microsoft and they announced that they will work together from now and will release Windows Smartphone.
Except then Nokia we can not found any company that works to produce  Microsoft Smartphone. I think this answer will clarify your idea.
Thanks for your good question.Â
Dear Clarence,
Don't take the above comment into consideration. If you do this you will be badly misled.
Ever since Windows Phone 7 came out Microsoft has worked with:Â Samsung, Dell, LG and HTCÂ in order to release their mobile OS on smartphones. When Nokia teamed up with Microsoft they became the 5th partner.
Thus, there are many phones for you to choose from and you are not limited only to Nokia handsets. My recommendation to you is to visit each manufacturer's website and decide for yourself which way to follow, what design suits you and finally which smartphone to buy.
I hope this helps.
