Nokia Ovi Suite Installation operation failed
Hi experts,
During the install of Nokia Ovi Suite I had this error. I have the latest drivers for my PC and this suite is up to date. I did a small research on the Internet about this error and nothing useful was found. Any solution on how I can run the installer without an error ? How can I solve this ?
Thank you !
Nokia Ovi Suite
Installation operation failed. Unknown error (code:2).
OK
Answered By 590495 points N/A #183562
When installing Nokia Ovi Suite, make sure you meet all the requirements. To make sure you are using the latest version, download Nokia Ovi Suite. It supports Windows XP [Home or Professional] Service Pack 2 or higher x86 only, Windows Vista [Home Basic, Home Premium, Business, Enterprise, or Ultimate] Service Pack 1 or higher, and Windows 7 [Home Basic, Home Premium, Professional, Enterprise, or Ultimate] both x86 and x64.
Visit Ovi Nokia System Requirements for the complete specifications. The minimum required RAM is 1 GB so if you have less you need to add more to have a better performance. In your case, if you are installing a slightly older version, download the latest version from the link above. Once downloaded, use this installer instead to install Nokia Ovi Suite.
If the installation still fails, use a different Nokia Suite. Download Nokia PC Suite 7.1. It supports Windows XP [Home or Professional] Service Pack 2 or higher, Windows Vista Service Pack 1, and Windows 7.
