Paul Adam
Posted on - 07/31/2011
Hi!
I am using Nokia 7610 mobile for the last two years and I use Nokia PC Suite 6.86.6.1. Recently, I have downloaded the update of PC suite software and I'm having problems connecting it to my PC.However, when I go to the Connection Manager it says:
"Connection to Nokia PC Suite failed. Please reinstall Nokia PC Suite. (Code: Init IMediaControl2)"
I've tried the Technical Support line and they told me to disconnect my internet, uninstall, use the Registry Cleanup, and then reinstall… But it still won't work.Please help?
kevinf
Nokia PC Suite 6.86.6.1installation problem
The solution for this error is complete registry cleanup after you uninstall. But you said that you have already done it.
People often do mistakes while using registry cleaning. First of all you need to complete all associated software and then go for registry cleanup. But if you uninstall some part of the software and then go for registry cleanup, your work will not be complete.
This loop holes aren't usually figured by the user. So I recommend you install the PC Suite and check all the additional features during installation.
Now after restarting go for un-installation and uninstall all those softwares associated with Nokia PC Suite. Now use registry cleanup . This should do the work.
If the problem still persists, then Format and Re-Loading the operating system is the only option left for you.
If you already tried reinstalling the Nokia PC Suite application and even used a registry cleaner then the problem is probably with the update you installed. Try installing the latest version of Nokia PC Suite. First, download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select Nokia PC Suite among the applications and click “Uninstall.”
Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and then delete everything it finds. This will remove everything the program created on your computer. When it is finished, close Revo Uninstaller then download the free version of CCleaner and install it. Once installed, start CCleaner and clean your system.
When it is finished, close CCleaner and restart the computer. After booting, download Nokia PC Suite 7.1.180.94 and install it. This is the latest and last version of Nokia PC Suite. See if this works. If you want to convert CCleaner to Pro, download the codes and follow the instructions.
