Nokia PC suite, an error occurred during the installation
Hello experts,
Downloading Nokia suite went pretty easy and it took me only few minutes to complete download. When I try to connect with the computer I stuck up with a problem. For your information I have the old version in my computer, but it has not affected in any way. I have lot of space in my system harddisk, then what might be the problem? Help me solve the issue.
Something’s gone wrong. An error occurred during the installation of assembly ‘Microsoft.VC90.MFC,version=”9.0.30729.4148″,publicKeyToken=”1fc8b3b9a1e18e3b”,processorArchitecture=”x86″,type=”win32″. Please refer to Help and Support for more information.
Answered By points N/A #178288
This issue means that there is a service not running on which the installation depends. The service is called “Windows Modules Installer”. If the service is disabled, any installation of such software that uses Windows Installer won’t complete successfully.
1. Go to Start menu >> All programs >> Accessories >> Run.
2. Type and enter this: services.msc
3. Scroll down and search for “Windows Modules Installer”.
4. Right-click and select “Properties”.
5. Check the following fields:
Startup type: Manual
Service status: Stopped
If these options are not set properly, set them manually. Optionally, you can set the “Service status” to “Started” by pressing “Start” button.
Now try to install the software. Also, try installing the latest Ovi Suite.
Answered By 590495 points N/A #315263
That error obviously means you downloaded a version that is not compatible with your computer. For 32-bit operating systems, you need to install the 32-bit version of the program. For 64-bit operating systems, you can install both 32-bit and 64-bit applications but sometimes a 32-bit application may not install. This can happen if the program has a 64-bit version.
If you are using a 64-bit operating system and the 32-bit program does not install, you need to download the 64-bit version of the program if there is any. If no 64-bit version is available, it means you cannot install the program. If you want to install Nokia PC suite, try downloading another version. Download this version on FileHippo: Nokia PC Suite 7.1.180.94.
See if this works.
Answered By points N/A #346767
The Microsoft Visual C++ 2008 Redistributable Package (x86) installs runtime components of Visual C++ Libraries required to run applications developed with Visual C++ on a computer that does not have Visual C++ 2008 installed.
Download Microsoft Visual C++ 2008 Redistributable Package (x86) from Official Microsoft Download Center
