I installed Nokia PC Suite successfully. However, while navigating a site I have failed to connect it. I do not know the reason behind the issue. Is it a problem with the software Nokia PC Suite? I do not know the matter.
Please help me to solve the problem.
Thank you for the help.
Nokia PC Suite Failure to Connect to the Internet
I can help you fix the issue with Nokia PC suite on your computer. Please make sure you have the following things checked.
>>Make sure your phone supports a GPRS or 3G connections.
>>Check if you have a valid data plan for your phone to browse the internet.
>>Make sure your Nokia phone is correctly connected with your computer.
>>Please check if other features are working fine on your Nokia PC Suite. Check if it is reading your memory card in the phone.
>>Make sure you have the latest version of the Nokia PC suite and check if the program is compatible with your operating system
If the above steps do not help, I suggest you to download the Nokia OVI suite from the official Nokia website. This will fix your issue.
Thanks and regards,
Skarbos Jay.
