Nokia PC Suite Installation Error
Hi, I have problems installing Nokia PC Suite.
Here are the technical details:
Which edition of Windows should be applied? – XP Home
Which Service Pack must be set up? – SP3
Which edition of computer collection must be set up? – 7.0.9.2
If I attempt to set up Nokia PC package I receive the pursuing concept at the setting up of advance monitor: Inside Fault 2203
C:WINDOWSInstallerba1d8d.msi,
-2147287008
Another Error appears:
Installing Function Unsuccessful
Critical Problem While Installing
I researched the "2147287008" element and discovered this web page. https://support.microsoft.com/en-us/help/888310/ Then downloading the hotfix, re-booted my PC and attempt just as before but even now unsuccessful.
Any ideas?
Best Answer by Sharath Reddy
Answered By 0 points N/A #147921
For this problem, you newly download nokia pc suite from  filehippo.com and newly install this software i have the same problem and i do the same thing
Answered By 590495 points N/A #147922
If I will be analyzing the cause of the problem here, the version of Nokia PC Suite you are installing probably doesn’t support your present edition of Microsoft Windows. Most of the time, Windows XP Professional is the supported edition of Windows XP and since you are using Windows XP Home, this might be the case even if you are already using Service Pack 3.
To further investigate the cause of the problem, you should check the system requirements of your Nokia PC Suite. If this installer came with your phone then I’m sure the system specifications of the software can be found on the CD’s case. If you can’t find it there, check your phone’s manual. Or, you may also visit Nokia to download the latest version of Nokia PC Suite compatible with your operating system.
Download the version supported for your phone’s model.
