frobenius
Posted on - 01/11/2012
After downloading a theme from an online site m.zedge.net on Nokia N75, it does not switch on after it goes off. The phone keeps displaying a message "phone start up failed contact retailer". What is the best way to solve this problem?
Lee Seen
Nokia phone start up failure.
You will need to do a hard reset to resolve that problem. For your Nokia N75 mobile phone you will need to follow the steps below to be able to do a hard reset:
You will need to press the press the following keys while the phone is booting up: the Caps shift, Space bar, Delete button and Power button.
For more information on how to use the keys mentioned above, you will need to visit the following link: http://ww17.project-dna.org/
One thing that you will have to note is that a hard reset will lead to loosing about everything that you had saved on your phone, you may be lucky if a few remain untouched.
-Lee Seen
Hi, Â
It will be a Virus infection. Try those steps for master reset for your phone.
Press * + 3 + call + Power on buttons on the same time
then provide your Lock code and Reset your phone
Try it.
