Miithc
Posted on - 12/19/2011
Dear all,
For my work I am using Nola pro free Accounting software, and I am using it on my computer. I got a new HDD and on it I got Windows XP Professional SP2. Now I am having problem with Nola pro. When I input information for an invoice when I need to finish it error message appears. More than welcome will be any help? I don’t know what is wrong.
Error 0.7 is the error
Thank you.
Mitch
NolaPro Free accounting error 0.7
May be your loan pro free accounting software is a damage of its lost data. When you got Windows XP professional SP2, you should need to reinstall your loan pro free accounting software. Now-a day, If you want to solve this problem, follow the below.
1. First reinstall your latest loan pro software. Before reinstalling, uninstall your old loan pro software.
2. After re-installing software, save your download file.
3. Then Run this by Windows Control Panel.
4. And follow the screening requirements.
One more than that, it would be happened for your new HDD resolution settings. So set up your screen resolutions in 32 colors Bit.
Thanks!
