Bashemath
Posted on - 11/18/2011
I installed the Mozilla Firefox, but I did not get any image, icon or fonts in my computer. What happened next was that I got an ugly logo of Windows7. I tried to seek troubleshooting procedures, but I did not find any. What shall I do whenever this happens?  Thank you.
Non-availability of image, icon or fonts in computer while installing Firefox
Hi Bashemath,
To fix your problems regarding the unavailability of image, icons or fonts in your computer you must try to check your Flash plug-in status.  You will know whether your plug-in is outdated. If you know that so might probably the reason why you can't be able to see images whenever you are using Mozilla Firefox. Â
To make it updated try this link :Â https://www.mozilla.org/en-US/plugincheck//Â Â
If the problem still does exist, try also creating a new Firefox profile in following this link:
 https://support.mozilla.org/en-US/kb/profile-manager-create-and-remove-firefox-profiles
Hope this might help you.
Thanks
Hi there user,
There are several types of ugly image on the screen. Did it look-like a corrupted image, Pixilated or literally just ugly? Pixilated images or icons are a sign of incompatibility to your unit. If it didn’t get fixed by a restart, you must check your version.
Here you can view the system requirements for Mozilla Firefox users.
 https://www.mozilla.org/en-US/firefox/23.0.1/system-requirements/
The other cause, although many would conclude a bit far cause of this trouble is your Antivirus. Software is defected; it could be a dysfunction of your antivirus. Make sure you have updated your antivirus for safety.
Thank you for posting.
Pixilated
