jdiaz
Posted on - 03/25/2012
Hi Friends,
I am using ageing Dell Dimension C521, upgraded to windows. All of sudden video wouldn't display.
This monitor works fine with other PC, keyboard lights up, HD whirring can be listened. Now can anyone help me out in solution. I really needed as to access my urgent files.
Non Visuality of Video display
HI there ,Â
It seems you are having trouble with the Video or Display of Dell computer . Since the display works with other PC 's the Monitor is working very fine . The problem is with the CPU unit. It maybe because of driver problems but if it was that the display would show some error.Â
But this case is different it doesn't display anything , just black screen right?Â
If the plug has complains or not connected then the monitor would show No signal error .
The problem is with the Graphic card or module inside the Pc . It has Malfunctioned .Â
I recommend sending the PC for Warranty and service repairs. Before that Contact Dell Customer service center and inform about this.
mazhar
Please check your PC's VGA card it may be loose, fix the video card as it should be if still problem persists then plug out the video card and place it in another slot of motherboard if still it doesn't work then please change your video card.
