Guys, I can't begin character collection. I need some help. An error message content appear like this: "reads a non yahoo software program on email"?
The fault message says it’s a non character software programmed on PC has modified communication industrialist, thus it can't commence. What should I do? I badly need your help please.
Non yahoo software program on email?
The error message is very much incomplete and it’s hard to determine what’s causing it on your computer. If this is the first time it happened on your system, try restarting your computer then try it again.
If it’s still the same, try checking your machine for possible virus infection. But before doing the actual scan, update your antivirus first then run a full system scan on your whole computer. If you are using Windows on your machine, be sure to scan the folder System Volume Information which can be found in the root of every drive.
This is a hidden system folder so make some changes in the Folder Options to view hidden files and folders in Windows Explorer. Make sure to check this folder because this is the favorite hiding area of most Trojan worms.
You may also try checking your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities, or PC Tools Performance Toolkit.
