I have Snow Leopard 10.6.7 installed on my iMac. I tried to install Norton Antivirus in my system. For this purpose, I installed Rosetta.
I have also added the following proxies for this purpose in the network settings:
liveupdate.symantec.com,
liveupdate.symantecliveupdate.com.
Once I am able to install Norton Anti Virus, the query pops up asking me if I desire to run LiveUpdate. However, once I click yes, the process stops after initial initialization and does not compete. The only option which I can then give is to restart the process.
The error which I get to read as follows: "Norton Antivirus Autoupdate cannot continue. Please run LiveUpdate or reinstall NAVM and restart (Code 10)” is the error I get when I restart.
This problem is really perplexing for me. I request the technology enthusiasts here to kindly post a solution to my problem since I depend on you guys! Please give me your valuable suggestions so I may get rid of this troubling problem.
I would be thankful.
Norton Antivirus Autoupdate cannot continue (code 10) on Mac Snow Leopard 10.6.7
Hi Jacklyn Andree, I searched a solution that may help you solve your problem.
The first thing you should do is to check if your Liveupdate is the latest version or version 5.1.2.
If you find it not the latest version download the latest version here:
After downloading, open it and install it on your computer. Hit continue and then at the license agreement just click continue, agree and install. After you finish installing just input your admin account together with your password then OK. After doing so the copy process now starts. When the process is complete just close it.
Hope this information helps.
I think automatic update of your antivirus is off. To start it
1. Go to the setting window from the icon of desktop.
2. Scroll down the list of setting and find the section labeled update
2. Turn on Automatic update by clicking the status.
3. Click OK to apply changes.
I think you will be able to do that.
Good Luck
galib
First I thing you should do is to check if your MAC. I think you cancel you antivirus Nortone because this antivirus is not good. You use Avast antivirus this is the best for your MAC .1st you install this antivirus free version. And I give you key
https://filehippo.com/download_avast_antivirus/download/3f0f6cf85120fa5ac62abb03aaeecda8/
After downloading, open it and install it on your MAC. Hit continue and then at the license agreement just nock me I give you this license key.
Thanks
Galib
