justin sy
300 points
Posted on - 03/21/2012
Hello experts
The browser only shows the following error message when the standalone antivirus obstructs a malicious website.
By the suite's Norton toolbar in the position of the browser shows a comprehensible message about the obstructed site with a link for a complete report.
Need your help.
Thanks a lot.
Malicious Web Site Blocked
You attempted to access:
http://app2.tsmon.co.kr/file/adden_os.exe
This is a known mailicious web site. It is recommended that you do
NOT visit this site. The detailed report explains the security risks on
This site.
For your protection, this web site has been blocked. Visit Symantec to learn
More about phishing and internet security.
Norton antivirus blocks web sites
Hey Justin sy!
You have installed Norton Antivirus for your protection. Basically Norton Antivirus creates a Firewall between you and the internet. Whenever you try to visit a site that has malicious virus, Norton activates its protection shield and gives you the message, which you are facing now. If Norton does not block that malicious site, the malicious virus will enter in your computer and will cause damages. However, there is an option in Norton antivirus that you can disable this firewall. After disabling it, you will be able to view the webpage which was blocked by the Norton before. But the malicious virus will enter in your computer in this case.
I highly recommend you not to disable the firewall to avoid the losses.
Thanks
