Few days ago, I had setup Microsoft office Professional 2010 for which Microsoft .NET framework 4 is given as complimentary. During the setup process,
Norton Ghost 15 ( V 15.1.0.36526) encountered the following error message given below.
Please help me to setup the software.
Looking for some solutions.
Norton ghost Installer Information
ERROR: Failed to have success running InstallVSSProvider function in MSIInstalllVSSProvider function.
Norton Ghost 15 ( V 15.1.0.36526) encountered error message
I suggest you to check the following on your computer.
>>Please check whether any other Norton programs are installed on your computer.
>>Check if the date and time is correct on your computer.
>>Check if you are installing a genuine Norton product onto your computer
>>If the above steps do not help, you should try reinstalling the Norton product.
>>Once the Norton program is removed from your computer, delete all the temporary files.
>>Try installing the Norton product in ‘safe mode with networking’.
This should fix the issue with the Norton product on your computer.
Skarbos Jay.
