Is Norton Ghost 2002 still supported
I am still using my Norton Ghost 2002. I've read somewhere that its support will be discontinued soon. Last month I was still able to update my copy. But the other night I remembered getting a pop-up error message but failed to record it. I check the Norton website but they don't have any information about it.
Best Answer by Goram Ian
Answered By 0 points N/A #191046
Hello Nelson,
If the support was said to be discontinued soon then you should better act on that early to avoid the risks your computer will be facing when the antivirus becomes un-operational. You can choose to get another antivirus software for instance AVG or Kaspersky and install it.
Nicke
Answered By 60 points N/A #191047
Hi, Nelson Carters
I have read your problem and I found it very much interesting. There is a lot of Abandon adware in different sites and I think Norton Ghost 2002 is one of them. Some computer user uses this software. It may solve your problem if you consult the other users about it.
I can suggest you some good forums, which are listed below:
Hope that helps you a lot.
Thanks and more power.
