AntonioV
Posted on - 11/11/2011
I have been working on Norton Ghost when suddenly I got this error message, see screenshot below.Â
When I hit the continue button, I got the same error message.Â
However, it said something about attempting to read or write protected memory. Was the memory corrupted?Â
I tried working on it again after rebooting but I got the same error.Â
I copied the details to Notepad but it was too long to put it here. Â
Any advice on what to do next?
Norton Ghost
Unhandled exception has occurred in your application. If you click continue. The application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Norton Ghost error – Unhandled exception has occurred
Good day AnotonioV,
All I can say and suggest is to visit the forums on the links below which is I am going to provide. Just be patient in reading it and make sure that you understand every single instructions to be able to solve your issue. All these solutions is what I have search on the internet. I hope it will help you solve your issue.
Informational Site 1
Informational Site 2
Informational Site 3
-Zorian
You just simply scan the application you just download the error repair tool and then after you download the error repair tool you just simply install that to your machine and then just simply after you install the application you just simply scan the software and then after scan the application you just simply repair the found error to your application and then you just simply try to check if there an corrupted file if there is a corrupted files you just simply uninstall the application and then try to reinstall it again to your machine and then I recommend that just simply restart your machine after your install the software.Â
Ben
