analyn
10 points
Posted on - 08/10/2011
What will be the limitation on using the Norton Ghost software? Does Trojan Issensial I will be helpful to fix the computer viruses? In what sense does the viruses can affect the other company software?
edward79
Norton Ghost software for the computer viruses
Hi Dear,
Norton Ghost mainly use for image copy. you can make your full computer image through LAN boot or directly from computer.
Any kind of operating system you can make image using Ghost software. Actually there is no limitation but now a day some people are asking that they are facing HDD Limitation, Like 1 TB. but as per my experience up to 1.5 TB there i did not found any problem.
You can only remove Trojan Viruses by using Trojan essential or essential cleaner.
If virus affect my computer then what I am doing first? I am going to buy a licensed Antivirus.
