Norton internet security 2012 vs 2013
Hi! My current antivirus is norton internet security 2012. I am still uncertain whether I should upgrade it to 2013 or not. I have read reviews saying that those who tried upgrading to 2013 were forced to revert it back to 2012 because of some updating problems. Can you please help me on my decision? Is it a good step for me to upgrade or should I just stick to the 2012 version?
Answered By 5 points N/A #179119
Hi Elin Ortie,
For Antivirus, it is important to update regularly. If you do so then we will be safe from viruses. You are using Norton Internet Security 2012 , there is no need to go to latest upgrade, because your database engine searches the same address what Norton Security 2013 does. In the latest update of 2013, there are some problem exists like auto save , auto fill etc , eventually, Norton fixes the problem and give latest patch to solve those issues.
So you can safely upgrade to Norton 2013 or go safely with existing 2012 version, just update database regularly, that's the important issue.
Hope this will help.
