Is Norton internet security good antivirus?
Hey friends,
I want to ask very simple question that is Norton internet security good enough for my PC. I'm using Windows 7 since 3 years nad I have used AVG anti virus till yesterday. Now I wanted to change it so downloaded Norton, please tell me is my decision right or not? Thanks in advance.
Answered By points N/A #186093
Norton is one of the best security programs all over the world. It gives a great security from all types of threats and good for any sort of use.
Norton comes in good and handy engine for detecting malware and resolving them. Its community is quite large that allows it collect information and provide better security.
There are many security applications that can’t resume updating process. If the downloading process of any update is corrupted, many security programs start it from the beginning. In this case, Norton is the best as it supports resume capability.
Norton provides quite good real-time scanning. While playing games, it doesn’t make any trouble. The system doesn’t get too compact where many aggressive security programs turn a robust PC into 50-years old machine.
It’s quite good and trusted. I’ve been using for 4 years and don’t have any issue.
To test any antivirus, you should test the EICAR fake virus test. Just copy and paste the following text into any text editor and save the document with COM file extension. The text is: “X5O!P%@AP[4PZX54(P^)7CC)7}$EICAR-STANDARD-ANTIVIRUS-TEST-FILE!$H+H*” (without quotes).
