Hi Experts,
I have recently installed EXCEL 2013. I am not able to convert XLS file which contains Macros to XLSM file. When I am trying to save through ‘Save As’ option it is not saving the file. The file still remain in XLS format. Even after I have changed the name no new file is creating in XLSM format.
I don’t know what is the problem with it.
Can anybody gone through these type of problem.
Please help me.
Not able to convert XLS file to XLSM file in Excel 2013
The only solution to your problem is to run the macro below, to convert XLS files to XLSM files, which has been tested and verified by many users.
Sub TrandformAllXLSFilesToXLSM()
Dim myPath As String
myPath = "C:Excel"
WorkFile = Dir(myPath & "*.xls")
Do While WorkFile <> ""
If Right(WorkFile, 4) <> "xlsm" Then
Workbooks.Open FileName:=myPath & WorkFile
ActiveWorkbook.SaveAs FileName:= _
myPath & WorkFile & "m", FileFormat:= _
xlOpenXMLWorkbookMacroEnabled, CreateBackup:=False
ActiveWorkbook.Close
End If
WorkFile = Dir()
Loop
End Sub
Hi Harry
I recommend you to visit this link zamzar converter, it is an online file converter that lets you convert different kinds of file.
XLS to XLSM or vise versa. You just choose the file you want to convert then choose the format you want the file to be converted type your email then the converted documents will be sent to your email.
