I am not able to install FOREFRONT TMG on my PC due to this error:
Forefront TMG Standard Installation Wizard
Setup failed to install ADAM. rn (0x80074e46)
OK
I am using windows XP.Is there any method to solve this problem?
Thank you.
Not able to install FOREFRONT TMG on my PC
Dear Otis Hartwell,
There are many reasons for not installed Forefront TMG Standard Installation Wizard. First Ensure your Installation package is all right from where you download this.There are may be a file missing. It may happen problem your windows xp. Let check your PC is virus free. You can try to after set up windows Again. And Must scan your whole PC to protect from virus. I strongly recommended you, please use PC Cleaner. And Antivirus.
I will be happy If you Install Forefront TMG.
Hi Otis,
First of all please confirm that your computer has the minimum system requirements to install and run the software. If all are fine then there might be a problem with the installation package. If it was from a CD/DVD there might be a problem with the CD/DVD. And if it is from the internet, then you have to download again from a trusted source
