In saving a picture in PNG format, whatever the name I chose or put, PSP informs,
"The file name is not valid"
But if I went with saving it in TIF format it instantly gets saved.
I also have noticed that whenever I attempt to save a copy of a PNG format file through SAVE AS dialogue, PSP always questions me whether it is sure to overwrite the existing file. If I click the YES button, then the file gets saved.
Since then onward I have been getting the following error message.
PaintShop Photo Pro
This copy of Paint Shop Pro has been damaged or illegally modified.
Please reinstall from your original source.
OK
I really exhausted with this.
Please somebody aids me.
Not able to save in PNG format
As what did I saw in the screen shot your Paint shop pro had crashed and you will cannot access it anymore. And one thing if you want to save a .png file it is not necessary that the software will tell you that there is an existing file which is not true right? I think your software was not installed properly. You have to follow these steps:
1. uninstall the paint shop pro software
2. go to your control panel "uninstall a program for windows 7. Add/remove for windows XP.
3. after uninstalling you have to download a software that is compatible to your current operating system.
4. or download the latest and updated version of the software.
