Not Able To Use Xbox Live Getting Error, Xbox 360 Error Code 80151904. Help Me People.
When I try to use the Xbox live service, I face an error, xbox 360 error code 80151904. I cannot proceed further without resolving this error, help me.
This error is related to the Xbox live services, so there is a strong chance that either Xbox Live service is temporarily down or you have a problem with your internet connection. Also, the profile you are trying to log in with can be faulty.
The following methods will help you:
When you try to use Xbox Live on Xbox 360, you may encounter error code “80151904” accompanied by one of the following messages:
“Can’t connect to Xbox Live.”
“Status Code 80151904”
“Sorry, Xbox Live profiles can’t be downloaded right now. Please try again later.”
This error code indicates a problem with the Xbox Live service. Another possible cause might be with your internet connection or your Xbox Live profile that is stored on the console got corrupted. To troubleshoot the problem, first, check the Xbox Live service status. If you see an alert, wait until the service is up and running then try again.
If this doesn’t work, try troubleshooting your connection to Xbox Live. On your Xbox console, press “Guide” then go to “Settings,” “System Settings” then “Network Settings.” Next, select the name of your Wi-Fi network. If you are using a wired connection, select “Wired Network” then “Test Xbox Live Connection.”
