Hello guys,
I bought an Acer Aspire laptop about a month ago. It had windows XP operating system.
It was running perfectly fine without creating any problems. Now recently I am facing some problems with it. Most of the time it gets stuck.
Then I have to restart it again to continue with my work. I decided to reinstall the windows so I did so.
I added the programs which I needed but when I was installing the programs, an error window started appearing on the screen again and again.
The screenshot of the window is given below:
Acer Empowering Technology
Sorry This is not a Acer system,
OK
I don’t have any idea what this message means and why it pops up again and again.
Has anybody else encountered such a problem? Please help me to resolve this issue.
Looking forward to your replies
Regards
Tony
Not a Acer system error message
The error is from Acer empowering software technology that you installed to your computer. For you to fix that one, you need to uninstall it. This software is use for empower management and I think it is not worth it. You can do all things that this software can do manually, so I think you don' really need it.
So to solve the problem is to uninstall the software. But if you really need that kind of software, you can use another one like Enet management or the Epresentation management.
Good luck.
I got your problem. This problem arises because of potentially harmful programs like spy ware, viruses, malwares etc.
You can use variety of applications like tune up utilities, advance system care.
For removing malwares, I will recommend you using Advance Malware Pro. I have personally used this software and got great advances.
This is not a big deal at all. It’s very user friendly software. After installation of this application, run an automatic scan. It will take some time. When it is completed, repair it. Your work is done.
Hope you will not face this type of problem again
Thanks for your time
