Not configured the EnterpriseDB Clusters
Hello friends, I don’t understand the reason for this error when I choose the online migration from context menu the error dialog box opens. Just want to make sure whether this is the only option available to migrate data? Do we have alternate one? I have a doubt does the data in the table affects? So help me friends.
There are no EnterpriseDB Clusters configured, Can’t launch dialog
Answered By 5 points N/A #179110
This error is likely a result of a disconnection. You must connect to the Postgre database in the Migration Studio as well as that of Oracle in order to perform this task. Once connected, you should be able to smoothly perform online migration with a simple right-click of the proper menu. If this does not solve your problem, you can experiment with an offline migration tool (e.g., a command line utility), which is specialized software for this purpose. Utilize a search engine to find one that is suitable.
