Windows 10 looks like a real gem as far as operating systems are concerned, but its new features leave with more questions than answers. First of all, will it be able to run on the older computers? What is the RAM and CPU speed requirements? How much information will Cortana give to windows about my computer usage? When and how will the windows holographic device relate to my computer?
Not enough information on windows 10
Hello Jason!
Here are some of the basic requirements for Windows 10 if you’re planning to upgrade your operating system.
1. Processor: 1 Gigahertz (GHz) or faster with support for PAE, NX, and SSE2
2. RAM: 1 Gigabyte (GB) (32-bit) or 2 GB (64-bit)
3. Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
4. Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
Cortana is your personal assistant that will be a great help in settings reminders, voice input for activating commands, and answer questions using different search engine tools or Bing. Holographic systems and devices will not be use commonly for now. In the future it will be used widely to be are means of replacement for monitors. I suggest not to switch to Windows 10, because there lots of features that you will not be able to use that will slow down the processes of your system.
