On my taskbar a balloon appeared and I clicked on it. This message appeared on my desktop. I have all the partitions and I have enough free space to all of them. Can anyone explain me please why I have this error ? Should I be worried about this error ?
Thanks !
Notice
There are not enough free space in selected Path!
Not enough space in the selected path
If you received that error after clicking a balloon or an alert in the Taskbar or in the System Tray then it means one of your applications has an available update. Normally, a balloon appears if there is an available update in one of the installed applications. Check drive C if there is still enough free space to install the update.
It will not display an error if there is enough free space available in your hard drive. To free up some space in the system drive, click Start, All Programs, Accessories, System Tools then select Disk Cleanup. Select drive C and click OK. Check “Temporary files” and “Recycle Bin” and click OK then wait for it to finish.
You may also check other items in the list that consumes disk space such as Temporary Internet Files, Setup Log Files, WebClient/Publisher Temporary Files, and others. After this, try the balloon again and see if it works.
