wadee
Posted on - 08/17/2012
I often get memory issue when i open multiple applications and working on it and when i try to open a new application keeping the other application open, it throws the different types of errors like Not enough storage command, Not enough memory, sometimes system just beeps and no error message and will not open new application, sometimes system hangs, sometimes new application which i open will be crashed. Temporary solution i had to follow is to close the existing application and open the new one.
Computer’s memory sometimes shows notification that you are running out of memory or your memory is to low, this is sometimes cause by multiple applications that are running in your computer at the same time or your computer is much likely infected by a virus, a worms or a malware. Check also if your windows registry is not corrupted. Scan your computer’s whole system; make sure that your security protection is up-to-date. All found glitches or infection must be deleted. Reboot your system in order to allow changes to be applied completely.
That particular application you used to open and get such errors, keeping it close go to its directory in C drive or where ever its program files are located. Find the Cache folder of application and delete it because that is the reason it consumes much memory and keep on disturbing the launching of application.
Whenever you will launch next time the application cache folder will be created automatically.
Hope that works!!
