Not Enough System Memory on running Zoo Tycoon 2 game
I have this zoo tycoon 2 sb live xfi problem. I just tried Zoo tycoon 2 and when it loads, an error message pops out that I don’t have enough system memory. I wonder what card or driver works well for this? Any ideas from Zoo tycoon users out there?
Answered By 0 points N/A #148878
1. Go to start Tab.
2. Then go to System configuration and then the boot option.
3. Click  on Advanced Options and then check on the box that says maximum memory and write 2046 . Click on OK.
Now start the game and it should work. However the problem is that after playing the game you need to check on the box again (Without typing this time). You will have to click every single time on the box after playing. It's annoying but is the only solution.
Thanks
