Not getting SMS updates from Twitter
I have noticed recently that I am not receiving SMS updates from Twitter. Is it due to overloading? I have checked all the settings and the phone number of the contact but still haven't been successful. Please tell me how to tackle this issue and start receiving SMS updates again..
Best Answer by Ware Shaul
Answered By 0 points N/A #148656
If you’ve already verified your settings (time zone, sleep settings and mobile update preferences). Try to un-follow and re-follow a person. Or you might as well try to reset you mobile preferences by texting the keyword “OFF” to your twitter code. Delay a few minutes and text “ON [your username]” to your twitter code.
I hope this tip will help you.
Martine Paul
Answered By 0 points N/A #148657
Hi Avery,
I believed that overloading is one of the causes of not receiving SMS updates. This is because some Twitter SMS queue is overloaded with text updates, as a result, it may drop. To address this issue, there are things need to consider.
1. Ensure that the phone number is added to your account. You can check it under Settings and then navigate to Mobile tab.
2. Ensure that the specified time zone and online sleep settings are verified and correct.
3. Ensure that the mobile update preferences are set to ON.
4. Ensure that the person you’re following updates are turned ON.
To know more about the SMS Updates, kindly click the link below.
Must Read Twitter Frequently Asked Questions – This link will guide you through the official support page of twitter. The support page highlights the frequently asked questions with the solutions on how to solve it.
Ware
