julia435
Posted on - 10/15/2011
I have HP laser jet 1300 the problem is that my printer is not printing. Some time it gave error, that low cartridge but after some time the printer has not started to print. I gave the command to the print but nothing is happened. I put the cartridge out and put it back but nothing happens.
Same tie error occur page ham or some time paper loaded but printer gave the option that put your paper in it.
So please help me so to solve problem. Thanks
Not print paper is acceptable. What is the matter?
HP LaserJet 1300 Printer series
I hope you are using this type of printer which is seen in this picture,,The problem in your Hp LJ 1300 drivers please reinstall the driver and install a driver according to your windows don't install another windows driver.
I hope this problem will not occurred again.
You might be printing a file with a different paper size and the paper that you load is not the same in the printer. Check your printing preference or properties before you print a file (see the image below for reference). Then you have to make sure that you have the right paper size.
I suggest that you use A4 by default.
You can also try reinstalling the driver. Remove you current driver installed then put your printer CD or downloaded driver in the CD drive. Run the setup and wait for it to finish.
I hope this solves your problem.
