Not Supporting: Windows 7 Home Premium Remote Desktop.
I have bought a Windows 7 Home Premium, but it does not support remote desktop connections. How can I enable Windows 7 home premium remote desktop?
A system with Windows 7 Home Premium does not support remote desktop connections. You need to upgrade the Windows to get this feature.
What you need to do is:
(i) Download and extract this zip file on your system.
www.mediafire.com/?z89saljm5asbp2
(ii) Go to the folder and then click install.cmpd and then run it as admin.
You can also enable multiple sessions for a single user.
Go to Start.
Open Command Prompt. Select Run as Administration.
Type "c:DIRECTORYTOEXTRACTEDFILES"
Type Install Multi.
Notifications
