Benjin
Posted on - 11/12/2011
I have not done any system settings to Vim but the change inner word command does not work. I noticed that this happens when I am using version7.1.138 on Ubuntu 8.04 on machine ciw .What could be the reason behind this?
Not working Change Inner Word command
Hi Benjin,
A pleasant day to you. May I suggest that you visit the links below and read them very carefully to get and idea on how to solve your issue. Make sure that you follow the step by step procedure. I hope that this will halp you solve your issue.
I hope that it will help you solve your problem. Best of luck. Please let me know if any of those solution will help you solve your problem. Thanks in advance
-Zorian
