Notebook with Ivy Bridge Processor
I am looking forward to buy a notebook with Intel's Ivy Bridge Processor .
Can you Recommend some from where I can choose ?
Thank you.
Thank you.
I just want to recommend the HP Pavilion DV7 7000 is powered by Intel Ivy Bridge Core i7 Processor, it has an 8GB 1600 MHz DDR3 memory with 1 TB Sata Hard drive. This Notebook is also powered with NVIDIA Geforce GT 650M 2GB GDDR5 dedicated graphics for accelerated processing power high-end discrete graphics it has a thoughtfully detailed aerodynamic styling, chrome accent soft touch surfaces. It uses the HP CoolSense, it uses the HP TrueVision HD Webcam with 17-inch Full HD display it also features the Professional quality sound of Beats Audio.Â
The touchpad is equipped with on/off button and support multitouch gestures, it has a Full-size keyboard with integrated numeric pad.
Hope this will help.
