I just installed some plug-ins for my Notepad and now I have this error. I have downloaded the plug-ins from a trusted source and all was recommended. Now I have this kind of error and I don’t know why. It says that I should remove some plug-ins to fix it. Does anyone have any idea about what plug-in should be removed ?
Thanks !
Notepad
The C:omegsparse.txt file is too large for Notepad.
Use another editor to edit this file.
OK
de Blair
10 points
Notepad cannot open document files
Well Notepad is meant to be a "Quality-Text Editor" rather then be a "Quantity-Text Editor". This consumes lots of computing memory for processing a comparatively a smaller text file. The latest versions of Notepad which include various plugins helpful for script processing, like "Notepad++" are assigned to through this kind of error messages in place of getting over worked up and ending up to "getting hanged", unlike older versions. You may consider:
Splitting larger files in to smaller fragments
Using better and proper text editors like Wordpad.
Hope this will help you.
