paulartney
1290 points
Posted on - 07/11/2011
Hi to all, I was doing some final touched of my html codes, in the middle of my work my notepad suddenly stopped and generated an error message, it tells me that there was an application problem, posted below is the actual error message.
Notepad ++ – new 1: notepad++.exe – Application Error
The instruction at “0x004525d5d” referenced memory at “0x00133000”. The memory could not be “read”.
Click Ok to terminate the program
With my years of using notepad, this is the first time I encountered such error, I even manage to open my html code file the other day, and I did not experience any error at all, I was so bothered with this error specially that I am about to finish my project, I scanned my computer for some virus, no virus was found, I also restated my computer after the virus scan, when I tried again to open the file, same error message appeared, please share some ideas on my issue, many thanks to all.
Notepad suddenly quits with Application Error
Hi there
The problem you discussed is looks like as a common problem that is noticed while using notepad and windows applications that may be resembles to the one you just met while doing your project. This error message is called notepad.exe is utilized for the purpose of handling huge data files having massive data load on the file and is also a hub for controlling and saving the data into the memory of windows.
The main threat of this kind of error is that it is not easily reachable and is difficult to be located and works like a worm which feeds data and removes it slowly and gradually from our files so should be handled with instant action.
It also paces down the working of the PC and hangs while we are working after a little span and applications will also be affected from this error or we can simply say a virus which stops the applications to start smoothly with its presence. So I should suggest you to contact the software vendor or an expert technician in solving complex problems because this kind of errors is difficult to locate and handle by using average pc skills.
Or you should also try to purchase an original version of the notepad.exe files scanner which will might help you in resolving the matter.
Thanks
