Nothing seen when I create either online shell script or online script
Hi all,
I have followed Adobe's guideline:
http://kb2.adobe.com/cps/921/cpsid_92186.html
Yet, when I create either an online shell script or online script, I get nothing. When I copy my install command and paste it into my test machine, it works.
I have triple checked my application.xml.override file. I made the appropriate changes to the setup.ini file. When I run the following on the local system, it works just fine.
Start /wait "\ServerPhotoshopElements10Setup.exe" /UL1033 /V"SERIALNUMBER=1111-1111-1111-1111-1111-1111 COUNTRY=244"
Has anyone else encountered this issue?
Is it a problem with UNC paths?
I need your advice.
