Notification error in PC Studio for Samsung – missing audio files
Hello experts,
My Samsung refuses to connect with my PC and I have this error. I don’t know how to solve this and after a small research on the Internet nothing useful was found. Can anyone help me please to fix this error ? What is causing this ?
Thanks !
Reconnect the device in Samsung Kies (PC Studio) mode.
OK
Answered By points N/A #178187
Such issue isn’t uncommon to Samsung Kies. You have to disable USB debugging mode so that your mobile will be connected easily to Kies.
1. From menu, go to “Settings”.
2. From the left panel, tap “Developer options”.
3. Remove the tick after “USB debugging” that allows debug mode when USB is connected to PC.
4. Connect your Samsung device to PC and try to access via Kies.
Now, your problem should have gone.
